altenbach
Flat controls, indicators, and containers
Status: Completed
Available in LabVIEW NXG 1.0. The default style of front panel objects in NXG is a flat style.
As soon as we have more complicated data structures (e.g. clusters of arrays), a large portion of the FP real estate is wasted taken up by borders, frames and trims, etc.
We need a palette full of "Amish" 😉 controls, indicators, and containers that eliminate all that extra baggage. We have a few controls already in the classic palette, but this needs to be expanded to include all types of controls, including graphs, containers, etc.
A flat control consists of a plain square and some text (numerical value, string, ring, boolean text, etc). A flat container is a simple borderless container.  A flat graph is a simple line drawing that would look great on a b&w printer. A flat picture ring looks like the image alone.
They have a single area color and a single pixel outline, if both have the same color, the outline does not show. They can also be made transparent, of course. If we look at them in the control editor, there are only very few parts.
Now, why would that be useful?
Let's have a look a the data structure in the image. There is way too much fluff, distracting from the actual data. If we had flat objects, the same could look as the "table" below. Note that this is now the actual array of clusters, no formatting involved! It is fully operational, e.g. I can pick another enum value, uncheck the boolean, or enter data as in the cluster above.
Many years ago in LabVIEW 4, I actually made a borderless cluster container in the control editor and it looked fine, but it was difficult to use because it was nearly impossible the grab the right thing with the mouse at edit time.
The main problem of cours is that the object edges completely overlap, making targeted seletion with the mouse impossible. (For example the upper right corner pixel is the corner of an array, a cluster, another array, and an element at the same time.)
So what we need is a layer selection tool that allows us to pick what we want (similar to tools in graphics editing software). It could look similar to the context help shown in the picture with selection boxes for each line. Picking an object would show the relevant handles so we can intereact with the desired object. Another possibility would be to hover over the corner and hit a certain key to rotate trough all near elements until the right element is selected, showing it's resize handles. I am sure there are other solutions.
As a welcome side effect, redrawing such a FP is relatively cheap.
Message Edited by altenbach on 06-03-2009 09:20 AM
38 Comments
approximately_whatever
Implementing this in NXG does NOT make it completed in LabVIEW ....
Can we expect something similar for LabVIEW? It's long overdue already ...
matt.baker
Active Participant
I got tired of waiting for NI.
Here is what I have so far (far from complete): https://drive.google.com/uc?id=0B6dFu9niJIpES08tNVlJcXBzTk0
drjdpowell
Trusted Enthusiast
I made my own flat (or almost flat) controls, “Flatline”, available on the Tools Network (latest version usually on LAVA).
d.w.b
Can this idea be reopened since NXG was obsoleted or does the idea need to be recreated?
Darren
Proven Zealot
LabVIEW 20xx contains NXG Style Controls, which are the same flat style as the default control style in LabVIEW NXG.
d.w.b
LabVIEW >= what year, specifically?
Darren
Proven Zealot
LabVIEW 2018 and later.
d.w.b
These controls CAN be saved as a prior LabVIEW version for use in older versions. Although the original post spoke of borderless, the NXG/2018 controls have the appearance of a 1 pixel border (like Flat Box). Actually, the 2018 cluster border is 2 pixels wide but the inner circumference defaults to the content area so it appears to be 1 wide but is FG/BG paintable to control both being different than the content area colors.
