| User | Kudos |
| 9 | |
| 7 | |
| 4 | |
| 4 | |
| 4 |
I would love to be able to show a ruler on the front panel....when turned on it should float above the objects on the panel...not unlike a cursor with lines in both planes if the panel was a graph. Unlike the grid this would make it simple to align e.g. columns when you have multiple tables underneath eachother. You could of course have this on the diagram as well, but the main use for such accuracy is on the front panel.
There are thirds party tools that do this, but it seems more natural to have it available in LV when we already have a grid that only solves a part of the alignment challenge.
National Instruments will not be implementing this idea in LabVIEW 20xx.
