13 | |
11 | |
3 | |
3 | |
3 |
The concept of fluent interfaces using method chaining applied to a LabVIEW block diagram would be awesome!
When calling .NET libraries from LabVIEW, block diagrams explode horizontally - the aspect ratio of the diagram can easily push 5:1 or worse (it's 10:1 in the example below). Some Method Chaining syntactical sugar would yield a more space-efficient-and-readable 4:3 to 16:9 or so.
Property Chaining is already well-established in LabVIEW - let's get us some Method Chaining!
See the first comment for footnotes...
