6 | |
2 | |
2 | |
1 | |
1 |
This one really bugs me. Currently if you control-click and drag a control to make a new copy the new one is selected
The very first thing I do after making a copy is to change the label. I use the auto tool so this usually means triple clicking on the label text and sometimes messing up the size to text setting. I propose that after making a copy the label is focused for editing with all text selected
I can not think of a way to get around the current behavior when copying multiple controls so this would only apply when making a copy of a single control.
Available in LabVIEW NXG. If you copy a control (either by copy/paste, or ctrl-drag), the label text is immediately selected so you can change the label without additional clicks.
