When I use changed font settings with a front panel object like a control and I want to adjust the font settings by opening the Font Dialog (Strg+0), this dialog always appears with the default application font settings.
To make this more user friendly, you should open this dialog with the already changed font settings. To open the application defaults you can add a reset button additionally.
