I often find myself in a situation in which I am intializing a cluster from other variables and I want to make sure I have defined all of the inputs. My suggestion below is to allow an option in bundling which if checked forces all of the elements to be wired up. This would ensure that if new variables are added to the cluster, this element would define them, instead of relying on the default value. This could also be applied to unbundling a cluster as well.
