Olivier-JOURDAN
Format into string function accept Error cluster
Status: Declined
Make possible that Format into String function accept error cluster as input as the following picture show:
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
2 Comments
tst
Knight of NI Knight of NI
Knight of NI
I would say that if this was implemented, it should probably be implemented for any cluster, and this would probably force the user to add a format specifier for each element in the cluster.
That said, I'm not sure I would want to see something like this. I understand the appeal, but I have a problem with the hidden nature of the cluster.
___________________
Try to take over the world!
Darren
Proven Zealot
Status changed to: Declined
