| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I find it a problem that free labels by default have the same color as native functions; there is no visual distinction in meaning. Hence I always have to change my free label colors... and I expect a lot of people use color on their free labels to mean different things.
*** SUGGESTION/IDEA ***
I suggest allowing the user to set the default FG/BG color of free labels in the LabVIEW Options.
Perhaps a different setting for Front Panels and Block Diagrams would be appropriate; that also would eliminate the "use transparent free labels" option from the Block Diagram options.
*** Other Train of Thought: not a full idea yet ***
As an interesting follow-up to consider I also suggest considering the use cases for free labels. Perhaps there should be a way for the user to create different types of free labels and assign them default colors; if that were the case it would be cool to be able to seach for "High-Priority Labels" in all opan VIs....
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
