In Front Panel we see that the Cluster is bound geometrically. It makes it easier for the user to create a cluster this way. But There could be other ways in which a cluster could be created. Say we have a new feature which allows user to group controls into a cluster like lvlib groups vi's, If a way to add controls to a cluster by name is introduced it would give each control freedom to be anywhere inside the front panel and not necessarily bound geometrically inside the present cluster bounds.
Please inform if any such feature already exists.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
