6 | |
5 | |
2 | |
2 | |
2 |
Hi All
if NI adds the Fuctional Global Variable (FGV) tempalte in design pateren tempates in hte New window, it is easy to create FGV VI's.
and Helps the programmers, no need to create from the begining of VI.
Even it is usefull for CLD Exam also.
