6 | |
2 | |
2 | |
1 | |
1 |
If you have mulitple versions of LabVIEW installed, some of them show up in the "Open With" menu, but regardless of which item you select, the VI will always open in whichever version of LabVIEW was opened most recently.
Example: if I opened a legacy VI in LabVIEW 2009, closed that version of LabVIEW completely, and opened another VI using the "Open with" menu and selected LabVIEW 12..., LabVIEW 2009 is relaunched and is unable to open the VI because it should have launched in LabVIEW 2012.
The current workaround is to add all installed versions as options in the "Send to" menu, but this is not nearly as intuitive as using "Open with" would be.
