11 | |
10 | |
3 | |
3 | |
2 |
Much like the ever-popular With with Errors, "Get Date/Time in Seconds" would be great with error clusters for inputs/outputs. This would help with coordinating timing (start/stop and duration).
Here would be an example of what the underlying code is that I currently use:
Pretty simple... and an example of what the use could look like:
And a duration example:
