In graph, the method "Get Plot At Position Method" get in input coordinates and output 'Plot num' as scalar value.
If more than one plot are superimposed, with this method I can get only one plot, is impossible get the other plot (for example with context menu): 'Plot num' should be an array.
Thanks all
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
