8 | |
6 | |
5 | |
4 | |
4 |
The Get Queue Status function will return all the elements in the queue - if you remember to set the "return elements" bool input to True. It's set to F as default. Why would I not want all the handy information from Get Queue Status but not want the elements?
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
