PaulG.
Get Queue Status function return elements default is set to = F. Should be set to = T.
Status: Declined
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
The Get Queue Status function will return all the elements in the queue - if you remember to set the "return elements" bool input to True. It's set to F as default. Why would I not want all the handy information from Get Queue Status but not want the elements? Smiley Indifferent
PaulG.
Retired
13 Comments
AristosQueue (NI)
NI Employee (retired)
> But when it comes to altering runtime functions it kind of spooks me
We are very careful to mutate existing VIs when we make such changes. If we cannot preserve existing functionality -- and I only know of one such in 10 years -- we mutate the diagram to be broken so that you have to come check it out. That one case was we fixed a bug, but some code existed that relied on the bug's existence.
altenbach
Knight of NI
The function is called "get queue status", not "return all queue elements", so the lightweight mode should be the default, in my opinion. If we simply want all element, the "flush queue" is the right function and it does not need any boolean.
The current behavior is correct in my opinion.
Darren
Proven Zealot
Status changed to: Declined
