6 | |
2 | |
2 | |
2 | |
1 |
The Get and Set Variant attribute functions are polymorphic on the 'variant' input terminal.
Why?
What do you expect of the following code:
I think allowing this is a bad technique in a 'early typed' language like LabVIEW.
Or am I missing something?
Ton
