10 | |
3 | |
2 | |
2 | |
2 |
I don't really expect this to get implemented because there are things far more important out there. But, I'm going to post the idea anyways. When creating a new VI, the default icon puts a number in the lower right corner. I have never used this number. I immediately delete it, grab the background color then dump paint to fill in the layer that was removed. You wouldn't think something this little would be so annoying, but it drives me nuts. I am curious if anyone else has similar sentiments?
This is especially annoying for classes because despite designing a default icon for the class, I still have to modify the default on every VI to remove the number!
