gsussman
Get rid of the "Bell" when opening the icon editor from the block diagram window
Status: Completed
Available in LabVIEW 2019 and later.
If you double click on the VI icon to open the icon editor from the BD window LV triggers the default beep sound.....why?
There does not seem to be any reason why this bell fires. The icon editor still opens, I can drag and drop from the BD icon.
Drop the beep and make it function the same as the icon on the front panel.
Admittedly this is one of those things that isn't so much a usability issue but more of a continuous annoyance.
Greg Sussman
Sr Business Manager A/D/G BU
19 Comments
TomOrr0W
The beep when clicking on the icon from the block diagram is still present in LabVIEW 2018.  It happens both for a single-click and for a double-click.
AristosQueue (NI)
NI Employee (retired)
Done.
This has annoyed me for years, but I don't have speakers on my computer at work, so I only think about it when I'm coding at home, away from LV source code, and I never remembered to fix it.
I have removed it from 2019 (it'll still be there in first beta because that's already in final prep). I'll tag it for consideration to patch older versions, though I suspect The Powers That Be will say its not a critical fix so will be reluctant to patch.
Darren
Proven Zealot
Status changed to: In Development
wiebe@CARYA
Knight of NI
A declined idea that is in development?
An idea with 1 kudo in development?
There's a first for everything...
That beep is annoying, so thanks for the bump TomOrr0W .
AristosQueue (NI)
Weibe: All I needed was the reminder at a time when I happened to be in the code base. Some things are easy to fix.
wiebe@CARYA
Knight of NI
And in this case, I'm glad common sense took priority over nr of kudo's Smiley Very Happy.
Darren
Proven Zealot
 It usually does.
Darren
Proven Zealot
Status changed to: In Beta
Darren
Proven Zealot
Status changed to: Completed
