Create a graph and display all its legends, the graph palette, X scrollbar etc. - you now have a rather messy mix of objects that are quite difficult to arrange together or in a compact and stylish manner.
The sizes of the objects should be made to match in different arrangements (preferably compact ones) and their default positions should be a good starting point, not a mess.
You could also have different layout/style options so when you choose to create a graph you get a number of layout alternatives to start from...kind of like the way you get in Excel.
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
