| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
There is no simple way to resize a graph.
To resize a graph you must set the plot area size.
Or to obtain the good size, befor you set the plot area size, you must calculate the difference between the graph control and the plot area size.
My suggestion is to have a property like GraphSize to directly read/write the graph size (like for string control).
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
