| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
It should be nice to have graphical tools toGET or SET a bit in an integer. (I8 , U8, I16, U16 ... )
Today it is possible to Set / Get bits with "Bitwise operators and, or ..." integer to boolean array, boolean array to integer ...
But i think this is a "C like programming way"
, not a LabVIEW graphical way.![]()
It should be interresting to GET the value of a bit using something like ...
It should be interresting to SET the value of a bit using something like ...
It should also be interresting to get / set a bit of an integer in a "Inplace structure"
I think this idea could clarify the way to access Bits in Labview ... and clarify the readability of a block diagrams.![]()
In place of using integer masks, integer to boolean array, and , or, XOR ... the set bit / get bit could be more userfriendly.
I think that this idea could also be usefull in LabVIEW FPGA.
Manu.net
