6 | |
6 | |
3 | |
2 | |
2 |
It would be nice, if the plot fill cold be set semi-transparent.
I have to plot minimum, maximum and average. It would give a better impression if the area between minimum and maximum is filled. Unfortunately the fill area hides the grid completely. It would enhance the plot if the fill was semi-transparent and the Grid would shine through.
I don't know how much effort it would take to implement a semi-transparent fill function in LV. If such a semi transparent fill function should be implemented could be implemented easily it should be done easily.
The picture shows a graph with (A) normal fill, (B) semi transparent fill (new idea) , (C) no fill
Does anybody else miss such a semi-transparent fill option (B)?
