| User | Kudos |
| 8 | |
| 7 | |
| 4 | |
| 4 | |
| 4 |
I would like if there were a default value for string controls that would be greyed out, but the string value would still be a blank string. This could be useful in showing example text for text that should be entered in a specific format. I have shown an example of the (visual) functionality and the code that goes along with it. This code could be greatly reduced if there was a key focus event added, but even in this case, the string control value itself is still not an empty string. I could also see this being beneificial in listboxes, multicolumn listboxes, tables etc.
