6 | |
6 | |
3 | |
2 | |
2 |
When using a Tab Control (Container) it would really be great to group icons so they do not float around the large container if used in combination with a case statement. Being able to group icons and anchor them at a location would really make life allot easier. This grouping should not alter position or arrangement during a clean-up operation.
Thanks!!
Functionality already available by wrapping code in a Flat Sequence Structure and selecting "Exclude from Diagram Cleanup" on the structure
