DanSome
Grouping or tagging controls and indicators
Status: Declined
It would be great to have some means of creating groups of controls that could be addressed en masse or at least displayed as a tree, by group. For example, all the controls on one tab could be in their own group. Then, the pop-up list of all available controls that appears when you want to 'Select Item' for a local variable would not be one long list, but would be organized as a tree; each branch would be the controls from one tab page. Same for the Event Case dialog.
thank you, NI and the entire development community!
Dan
6 Comments
labview4steve
The very least should be for LabVIEW to sort them ALL alphabetically rather than just some alphabetically - there is already some sorting - but you can't tell at a glance whether they are inputs or outputs etc...and its a major pain to sort through hundreds of local variables
crossrulz
Knight of NI
You shouldn't be using locals anyways except for very specific reasons.  Sounds like you should look into new architectures.
Knight of NI
If this is meant for local variables, then I agree with crossrulz. Any situation where you find that you need this is indicative of a problem with the architecture, not with the IDE. If it is meant for other uses, then I'm not seeing where this can be used. Please clarify.
DanSome
Maybe I'm just a cranky old-timer (17 years of LabView!) but I like my architecture, local variables, global variables and all - and I've got good reasons. But it's not just those that would benefit from grouping. My biggest peeve right now is the Edit Event Case dialog, when you have a couple hundred controls in the list and have to scroll through all of them to find the one you want to edit. A grouped/tree structure (with alphabetization to boot!) would make it very easy to navigate by collapsing irrelevant groups. Additional possible uses:
searching for all members of a group on BD or FP
setting common properties
[your ideas here]
Dan
tst
Knight of NI Knight of NI
Knight of NI
Personally, for the event structure dialog, I would prefer a filter control, which would allow us to show only the controls that match a particular string, but I believe this should already be in one of the other ideas, at least as a comment.
___________________
Try to take over the world!
Darren
Proven Zealot
Status changed to: Declined
