Hi
This an extension to the idea which I have submitted.
I had difficulty when accessing the control names on the front panel have more number of controls and also when we have same control names in the different pages of Tab Control.
It would be good if they can be grouped by Tab Page under the Event Sources in the Event Structure as shown below. This is similar to what the LabVIEW does when displaying the Cluster Variables in the Event Sources.
It will be helpful it the idea can be extended where ever accessing the controls/Indicators from the Tab Control Pages.
