10 | |
3 | |
2 | |
2 | |
2 |
About the function palette session in (Connectivity -> Webservice)...
The function generate a cookie, but we cannot change the name of the cookie (random value) or the property http only.
It would be nice to have more access to the structure of the cookie.
An other issue of this palette:
If I use the function Get Session and Destroy Session the http request of the client application (or browser) ends with a bad request, while the cookie is deleted from the client.
kind regards
Christof
