Hooovahh
Have Post / Pre Build VI For Installers
Status: New
If someone would have asked if there was a setting to run a VI after an installer was build I would have said yes, until today when I realized I needed it and couldn't find it.  When building an EXE there is a Pre/Post Build Actions section where you can specify a VI to be ran before the build or after it.  But this appears to be limited to building EXEs and not installers.  There are several limitations to the NI building process, and I'd like to improve them by having functions get ran after a build of an installer is complete.
EXE settings
Installer Settings
3 Comments
Hooovahh
Proven Zealot
Oh I may have found a duplicate idea after posting this.  It is for Zips and Installers which might be why I didn't find it or read close enough.
BertMcMahan
Trusted Enthusiast
Kudo'd both this and the other idea, I ran into this today- it'd be nice to be able to build an installer to my local c: drive and have a VI run to copy it to the correct network location for me (in addition to the many other uses, of course!)
Mr._Jim
Active Participant
I need this. I have to sign my installers, and hard coding my own personal certificate into the installer build spec is silly.
On my executables I use a post build VI that automatically looks up the certificate depending on the PC and runs the command with the correct arguments.
I wonder if there's some hack to get this functionality.
