11 | |
8 | |
3 | |
3 | |
2 |
The idea is that if you need a property node for a single property item, the property node would look more like a VI, where the error out is located at the bottom.
For example, how often do people use the "Bytes at Port" property node only to crosswire the error cluster and the number of bytes at the port.
See image below:
The suggested node would have a single property in the center and have the error out at the bottom. This would permit to have a nice routing of the wires at the output.
Of couse, we could always create a sub-vi which contains the property node and thus has the nice straight wires to go to the VISA Read.vi.
Let's see what other people think.
