The layout of the tree is built around a rubric. In programming we want more than one.
options:
I have a tree that looks like it is ~20 layers deep. There has to be a better way to handle the extreme zoom-out. When I print this the borders don't show up.
I should be able to left-click an icon in hierarchy and select "show all connections" and get the same formatting as in the "find".
The following is a trimmed and somewhat scrubbed subset, but it gives a basic overview of what I am given to work with. You could make tools that make handling and simplification of this easier.
Also, you could make tools to suggest sub-vi's in a chain (single series, limited cyclomatic complexity) into a single sub-vi. This is the meta-block diagram.
