| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
It is very common to build an array or string in a loop using the Build Array or Concatenate String primitives. Unfortunately, while easy, this also incurs a large performance degradation (see this post for some examples) and this is not communicated to the creator in any meaningful way, other than slow code. I propose changing the primitive appearance in some obvious way to show that a performance degradation is happening. This would only happen if the primitive was in a loop, since these functions are a normal part of LabVIEW programming. Some possible methods of showing issues:
Accompanying any of these would be a mouse-over or pop-up to explain why the colors changed. The change would also be explained in the context and primary help. I would definitely want a switch, probably in Tools->Options and the labview.ini file to turn the behavior off for advanced users. New users would see the change and should be able to find out why it is occurring fairly quickly. The help files for the nodes should give alternatives for using them in a loop, such as the post above or replacing a Build Array with a conditional index.
The majority of the problem comes from Build Array, Delete from Array, Insert Into Array, and Concatenate Strings, so an initial pass at this problem could target them only. The Build Array and Concatenate Strings issues could be largely removed by using compiler optimizations similar to the ones currently being used for the conditional index, although algorithm changes by the developer can lead to higher performance than the generic case (see link above). The Delete from Array and Insert Into Array issues are usually solved by algorithm changes on the part of the developer, so an indication of an issue would be useful.
