13 | |
8 | |
3 | |
3 | |
3 |
When you right-click on a connector pane terminal, a context menu pops up -- but there isn't a good indication of which terminal you've clicked on:
You could assume that selected terminal is at the top-left corner of the context menu, but (due to a bug, I'm assuming), the actually selected terminal is a few pixels down and to the right of where you clicked.
What if the terminal you right-clicked on got highlighted while the context menu was shown? This would provide visual feedback of the selected terminal, giving you confidence that you clicked on the terminal you thought you clicked on (and avoid mistakes of configuring the wrong terminal). I can't even begin to count the number of times I've set the wrong terminal to "recommended" or disconnected a different terminal than expected. Could look something like this:
(which just piggy-backs on the appearance when you're wiring up a terminal:
Bonus points if the bug gets addressed where clicks are actually a few pixels off.
