I am re-introducing an existing idea which was declined, by offering a solution to the issue NI identified in implementing that idea.
The idea was submitted by Ali-Amin and I have copied the original text below. Read on to find out what is the solution I am proposing.
While using Highlight Execution for debugging, we end up scrolling the code to know which part of the code is currently executing, and loose context of the code due to scrolling. We could avoid this by letting 'Execution Highlighting' do the scrolling for us. Execution Highlighting with Auto Scrolling can be invoked on demand. The default behavior of the Highlight Execution will not Scroll. We should provide mechanism for users to disable or enable this while executing the code.
Also in case of state machine,
