13 | |
7 | |
3 | |
3 | |
3 |
Automatic Error Handling (AEH) is a useful feature. It captures errors that were otherwise left unwired by the programmer (intentionally or accidentally). It represents a "safety net" that can make the programmer aware of errors that they may otherwise remain unaware of.
Problem: Currently AEH functionality is only available in the development environment. It is not available in built executables. Even when all VIs in a project have AEH enabled, once built into an EXE, all VIs behave as if AEH was disabled.
Solution: It should be possible to honour each VI's AEH setting in built EXEs too, not just in DevEnv. The EXE build specification could contain a setting named "Honour each VI's Automatic Error Handling setting in EXE". When ticked (enabled), any VIs for which AEH was enabled in the development environment will continue to benefit from AEH behaviour in the EXE. Any VIs for which AEH was disabled will continue to have it disabled in the EXE. This means that, from an error handling/error manipulation point of view, the application would behave identically when being run as an EXE as when being run in Development Environment. This is more consistent, and can be helpful.
The current behaviour (forcibly removing AEH in EXE) means that EXEs are prone to having errors that were not discovered during DevEnv testing being "swept under the carpet". In other words, currently EXEs are overly "optimistic" - they can make the programmer believe that everything is ok when in fact one or multiple unhandled errors are occurring, errors that would have been visible in DevEnv. This is particularly relevant to apps that run for long periods of time (e.g. life cycle testers) that may encounter errors that were simply unforeseen or untested in DevEnv (e.g. error after one month of continuous running due to running out of disk space when saving measurements log file to disk).
The screenshot below shows how the new setting could look like in the Advanced page of the EXE build spec.
Notes
