Just like we can put any image as a pane background, it would be nice to be able to use an image for splitters.
If you are using an image for the panes, the splitters really stand out. You can try to match the color as closely as possible but if there is a gradient in the pane image, it just doesn't work. Here is an example that could really use an image for the splitters.
In this case these panes are used somewhat like column headers for a whole bunch of controls/indicators below. If the splitters had the same image as the pane, they would be invisble and the FP would look cleaner.
