nodnarb90
Implement Python-Style Array Indexing
I think it would save a bit of space, and time, if we could use a negative array index value in order to quickly get the last element of an array.  This would also work for 2nd to last item, 3rd to last, etc.
Python Array Index Example
When I started working with Python I thought it was rather useful and intuitive to be able to quickly reference the last item in an array in that way.  Like so:
>>> a= [1, 2, 3]
>>> print a[-3]
1
>>> print a[-2]
2
>>> print a[-1]
3
10 Comments
garrettmarsh
ToeCutter
Active Participant
Like the idea, but want to keep array indexing quick and light and this would add another branch in the internal code. As an alternative, how about NI adds a separate function 'Index array from end'?
crossrulz
Knight of NI
Use Reverse 1D Array before indexing if you want to go from the end.
garrettmarsh
Also, if this were implemented, you would run into the problem of breaking code which relies on the current behavior (that a negative index returns the default value for that data type).
GregFreeman
Trusted Enthusiast
I agree with garrett...I think this is not feasible for the reason he listed.
lvABC
I use Delete From Array Function to get last element where the default is the index of the last element in the array.
http://zone.ni.com/reference/en-xx/help/371361j-01/glang/delete_from_array/
nodnarb90
Getting the array size and decrementing isn't so cumbersome that I think another method should be added specifically for that function, but I do realize it would probably increase the operations it takes for that function to complete.  I would just like to have the ability to index in the way that Python does.
I am aware that an "out-of-bounds" index will return the default value for that array data type, whether that index is too large or too small (negative), however, I don't believe I personally have ever created code that relied upon that.
The idea of a negative index is universal and could also be applied to other functions, such as string subset, to quickly get the extension.  I do realize there are functions to do this, and that it wouldn't be done this way because not all extensions use 3 characters, but this is just a demonstration for demonstrations sake.  See below.
Thanks for all the input!
altenbach
Knight of NI
I think we should keep all discussions in the original idea thread to avoid duplication of effort. I don't want to repeat everything I alread said.
JordanG
NI Employee (retired)
Yogesh_Redemptor
To my knowledge this may lead to confusion, because '-1' index mean not valid or search not found.
We should leave '-1' for the same and should not use for other purpose like to index last data.
Yogesh R
Yogesh Redemptor
