Currently LabVIEW provides the ability to apply the library icon to all the member VIs through the "Apply Icon to VIs" button on the library's general settings property page. This action applies the icon to all the VIs in the library and sets them as modified, even if the VI had the same icon before. Consider the case where you move a VI from one library into another. In this case, you want to apply the library icon for the destination library to the VI. The "Apply Icon To VIs" would be overkill, especially if the library has a large number of member VIs. Rather than the "Apply Icon to VIs" on the library, it would be very useful to have a "Apply Library Icon to VI" action that you apply on the VI in question that would apply the owning library icon to the VIs icon. This action would only modify the one VI that needs to get the new icon.
