Why is it that when you go to Select a VI from a packed library, all of the careful work that the developer put in to add folders, protected statuses, etc are completely discarded?
Surely it would be so much easier for people to find the RIGHT VI from a PPL if instead of seeing a flat list of VIs like this:
They were to see something much more like the what they get in a project view:
(In this particular example things are extreme as the lvlibp is a plugin interface so it has an awful lot of protected VIs, that the "user" of the PPL does not care about (and cannot even use directly).
Surely something can be done with this dialog that looks like it hasn't been touched since Windows 3.1!?
