2 | |
2 | |
2 | |
2 | |
1 |
The Wire Multiple Objects Together QuickDrop tool (Ctrl + W) is extremely useful. However, at the moment it has the following limitation.
The other day I found myself writing code like the following.
Naturally I tried using the QuickDrop Ctrl + W tool. However, it produced the result seen below, which is not what I wanted.
The Ctrl + W tool wires each source wire to a compatible (coerceable) destination. In the example above it wires to I32 and DBL destinations indiscriminately.
The desired outcome would be achieved if the tool preferred wiring to destinations that match the source data type exactly, before considering other compatible (coercible) destinations. In the example above, the tool should prefer the DBL destinations. It should wire to the DBL destinations first, before considering I32 destinations.
Notes
