When you use the sturcure element in place, there are often clusters with parameters and work values.
The parameters used may have to update the values.
Currently, the code is quite complex and quickly becomes difficult to read if the cluster is Comlex.
A solution is to have the possibility to use "read only" item from a cluser.
