JÞB
Increase Icon Resolution
Status: New
Since 1986, when LabVIEW first launched, there has been one constant.  Icons are 32x32 elements.
That made sense on 17inch CRT monitors.  There have been improvements in displays since then but, no corresponding improvement to the Icon resolution.
Isn't it time to change that?
5 Comments
_carl
Active Participant
Higher resolution = bigger icons, sub VIs taking up more space on block diagrams.  I would not want to see this.
srlm
LV NXG had larger icons. There was considerable pushback by users from the amount of screen real estate lost even on denser monitors and even with the zoom capabilities. It was never clear how much of that pushback was just "it was new so yuck" vs actual problems caused.
thadyale
How about we allow vectors in the VI Icons?  Then you can have them whatever size you want.
thadyale
Gosh and maybe an alpha channel.  But I guess that's too much to ask.
wiebe@CARYA
Knight of NI
There is an alpha channel. It's just 0 or 1 (100% opaque or 100% transparent), but it does allow parts of the icon to be transparent.
