6 | |
2 | |
2 | |
2 | |
1 |
I imagine the index array function already has to do a range check. The compile code probably looks a little more like this:
Since it's already doing the check, it might be nice to optionally return the result of that check so we can be sure our data is not defaulted. Maybe the icon could look like this:
