By decreasing the size of a formula node, code can be hidden without indication.
Example:
Before resizing:
After resizing, for example:
My idea is to either
* automatically show the scrollbars when code is hidden or
* indicate that there is additional code.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
