3 | |
3 | |
2 | |
2 | |
1 |
According to my understanding and the following discussion:
http://forums.ni.com/t5/LabVIEW/Why-exactly-can-t-I-inline-this/td-p/3126562
certain types of Property nodes and Invoke nodes should be inlineable without any great problems.
I would suggest that the LabVIEW compiler get's a bit smarter about this aspect of limiting the ability to inline code. If there's no technical limitation regarding inlining of a property node or Invoke node which is fed with a reference (which does not originate from a local object i.e. a static reference to a FP object) then it should be inlineable.
Available in LabVIEW 2019 and later.
