8 | |
6 | |
4 | |
3 | |
2 |
When you use "Labview Web server", you cannot access your Labview front panels using IE from a PC with no Labview Runtime.
To make it work you have to install a Labview runtime, or deploy manually some dll's ...
So, it would be nice to create a "light Labview Web client installer" in order to only install the minimum required.
Manu.
