When integrating libraries written in C# a common scenario that occurs is the necessity to cast a method to a generic delegate defined in the class in order to, for instance, subscribe callbacks to events belonging to sub-classes inherited by the object instantiated by the Constructor Node.
So far LabVIEW efficiently allows to subscribe to events, registering a VI as callback in case the event involved is fired, but does not allow to cast a VI to a generic delegate and that's very limiting.
The only workaround existing is to wrap the C# library, adding an additional C# layer that instantiates the delegates on behalf of LabVIEW and then exposes plain methods, properties and events that are straightly callable by LabVIEW itself.
The idea is to allow LabVIEW to instantiate generic delegates based on the definition of the delegate provided by the C# library and return the delegate object so that it can be provided as input to library's methods requesting it.
This feature would make the LabVIEW integration of C# dlls more solid and completely manageable within LabVIEW code without further wrappers needed.
