2 | |
2 | |
2 | |
2 | |
1 |
I have code I want to run in parallel, I've confirmed that if I write the code 3 times to execute in parallel there is no problem doing it. Yet when I try to put the code once in a for loop with iteration parallelism on, set to 3 parallel instances, it will only run 2 at a time because my target cRIO only has two processors. I suppose this is a requirement if we want the code to be truly parallel. But in my case, I'm satisfied with them running pseudo-parallel using whatever behavior happens when I write the code 3 times in parallel and they appear to execute in parallel. So like a timed loop, I'd like an option to set iteration parallelism to be either a) targeted to available processors OR b) just let them be launched in parallel asynchronously regardless of number of processors, and perhaps not truly parallel (with appropriate warnings). See attached image
Note - Specific to Softmotion: I realize there are theoretically other ways to do this asynchronously built into Softmotion, but they did not execute as expected. Yet this is just about the loop iteration parallelism.
