 ClaudioH
			 on
		03-15-2011
		07:11 PM
			3 Comments (3 New)
			ClaudioH
			 on
		03-15-2011
		07:11 PM
			3 Comments (3 New)
I believe that an express VI that implements a Karmaugh map to solve a boolean equation would be good.
The VI should receive the input, request the output(s) name(s) and provide to the user "truth table" the define the boolean equation.
At the end, the VI should provide boolean gate array that fulfill the table.
Ref. http://en.wikipedia.org/wiki/Karnaugh_map
This would help us to implement complex logics with simple boolean algebra expressions.
Cheers.
