2 | |
2 | |
2 | |
2 | |
1 |
After selecting an entry from the quick drop list I have to re-open it again for each item I want to place. Why not adding the possibility to keep it open showing the last selection? E.g. if I select the TCP Open item most likely I will use a TCP read or write in the next step. I think this could be easily done by copying the behaviour of the Control-/Function palettes which have a Pin to make them sticky.
