6 | |
2 | |
2 | |
1 | |
1 |
Sometimes when you are working on your block diagram or your front panel you accidentally scroll off screen or are in a different position and would like to snap your screen back to center on your code instead of scrolling all the way back. Having a built in keyboard shortcut would be really nice for this.
For example, I click and drag to select something and accidently go too far.
Now I can press a keyboard shortcut to return to my original code view
To handle cases where the block diagram is bigger than one screen, it could snap so that the top left corner of the visible screen is aligned with the highest and leftmost element on the block diagram.
As an extension of this idea - it would be nice in some cases (especially LabVIEW FPGA when you have many parallel loops) to be able to set certain points on your block diagram that you can snap to and have your screen center on that point. However I am hesitant to post this as a seperate idea because it has the potential to be misused by people who develop massive spaghetti code block diagrams.
Thoughts?
